Spark plug problem
06rickyd
Car: 1993 240 sx
I have a problem with one of my spark plugs it keeps fouling out everytime i replace it what could be causing the one plug to be fouling out?
s13sickboi
Car: 1997 Nissan Hardbody XE
Lot of things, check compression in that cylinder and you may find out it has low compression.
Or the plug might not be firing, grab a timing light and check that!
sly240
Car: 93 240sx
make sure the fuel injector is firing on that cylinder if it is sticking it can be running rich and fouling it out.
ShouldaHadaV8
Car: 92 hatchback 240sx, j30 diff, TIEN tie-rods
Could be bad valve, or seal. Deffinetely check compression, its good to know regardless
