Spark Plug gap?
ca18detdrift
Car: 89 240sx
I got a set of NGK bcpr7es-11, but wanted to know what the gap should be set to? is it 35-40mm? Thanks in adavnce!
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
i usually just throw them in....
- tim
iliketocrash
not trying to be mean but please check the faq or one of the stickies in the forum. i know for sure its in there.
ca18detdrift
Car: 89 240sx
I did check but couldnt find it, I did see someone asking if it was 35 - 40 mm before a while back using the search tool. I'll try checking the stickies once more but i swear i didnt find it.
float_6969
It's clearly listed in the CA18DET Engine Facts Sticky.
1.1mm
And just FYI, you might want to think about your distances there for a second.
40mm = approx 1.5 inches
You'd need some HELLACIOUS coils to fire a plug gapped at 1.5 inches.
ca18detdrift
Car: 89 240sx
I think i found it in the stickies.. "Spark plugs 22401-58S16 (PFR6A11, CA18) Non resistor type NGK BCP6ES11 (11 = gap of 1.1mm) "
I actually got the NGK BCPR7ES - 11 but I'll assume the "-11" means 1.1mm of gap as well. found it, thanks guys!
