nissanfreak12 wrote:z.Leinbach wrote:I have a spare tyre and bolt that I am not going to be using I can sell
Apparently you can't read or are ignorant, cause here is a guy trying to help. Chances are no one knew what the size was and since you are just a complete lazy a** and couldn't look for the size yourself, you decided to be a prick to the community. Good luck with all your en-devours without any help on these cars, since obviously you needed some help on just a bolt size.
Very glad you responded in the manner that you did as it gives me the opportunity to correct you as well as expand upon this Forum in general as well.
First off, apparently YOU can't read or are ignorant as I specifically stated that I did not want to buy an OEM piece. Therefore, the ONLY response I received was an unsolicited offer of a used part.
Secondly, if "no one knew what the size was" and no one was able to find out the size, what does that say about the technical knowledge here on the Technical Forum?
Thirdly, apparently I was neither too lazy, nor unable to look for the size as I found it out all by myself. It took about 2 hours of my time, but I got it done.
Lastly, if I wanted to be a "prick to the community" I would have kept the information to myself, but instead I posted it for everyone to see.
For what it's worth, Forums are set up for people to help each other out with the sharing of knowledge to make their experiences better. If not one member of the entire "community" is willing to take 5 minutes to pull back the carpet on their car, unscrew a bolt and put a die on it to help out another member, how strong is that community to begin with?
Now, if you're upset at this response, please go back and read it again and you'll realize that I am not looking to pick a fight, just trying to point out that we should all be trying to help each other out. While I am new to the Z32, when the time comes hopefully I'll be able to help someone else out with an issue they're having.
