Spacers are on - Updated with pix
audtatious
So, I just finished installing 15mm spacers on both the front and rear of the coupe. While not a difficult task it was made difficult by doing it in my garage that has crappy cross ventilation. Upper 80-low 90 temps and 60% humidity was made worse as the garage was probably 15 degrees or more hotter.
So, results? At first I was like "uh oh" when it sounded like it was rubbing when turning corners. I sure didn't want to spend the time in the garage to remove them again. Luckily, it was just the inner fender liner which hangs down a lot near the fender lip. It rubbed down quickly and all was well. The spacers brought the wheels out to the point they look bigger because they fill the opening better.
Updated:
MUCH better!!!!
audtatious
Werd
Final pix will be tomorrow I'm afraid.
audtatious
got them up. Not the best pix but they will do. Bad lighting.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
vast improvement....
quit crying about the hot garage already... good for your old a** to get a sweating in occasionally.
audtatious
Stop being mean to me
timmy0257
Car: 08 Infiniti G35 Journey 5AT
-R2C Intake
-interior LEDs w/ tag lights
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Future Mods include GT-Spec strut bar & more.
awesomne license plate..or was that an edit?
audtatious
Yeah, it's an edit. I doubt they would allow it ;)
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
ehh i have seen some pretty wild plates
Fezzik
Car: 2010 G37 Vert w/ stage 1 GTM supercharger
Looks good Matt. This is something i was looking at. I was thinking 20mm all around but the 15s look good too. your on eibach(sp) drop right?
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
Fezzik wrote:Looks good Matt. This is something i was looking at. I was thinking 20mm all around but the 15s look good too. your on eibach(sp) drop right?
he just put BC coilovers on. had Tien previously, i believe.
audtatious
Yeah, what Timmy said, BC coilovers :)
The ones I put on are 15mm. I may have been able to go 20mm but I'm happy with what I have which is effectively a 28mm offset. Your coupe wheels are 30mm so putting 20mm spacers on would effectively put you at 10mm. Doubt that would work :)
timmy0257
-R2C Intake
-SBD grounding kit
-TBW engine cover
-Eibach Pro-kit
-JL Audio
i love it. i would do the same after my eibachs go on this weekend, but i am not sure there is enough value there with my stock wheels. =/
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Lookin' good Matt. Much better stance.
KoZZ76
Car: 2007 Infiniti G35 Sport Coupe
agreed....she looks great with the wheels all nice n flush with the fender! Holy Crap indeed ;)
