Something other than an SR, CA, RB, JZ, VG, 350, swap
Truck
Car: 1989 Nissan 240sx XE
How about a RB30. It is a RB30e block, with a RB25-26de head. I believe lots of aussies do this motor build. You could even take it a step further, and stroke the motor, this may yield perhaps a RB34? I don't think that has ever been done. But if your going to do that, I suppose you could just get a 2jz, and stroke it... there are truly many possibilities.
PapaBurgundy
Car: 1991 240SX coupe SE CA18DET. 99 Dodge 2500 Cummins TURBO DIESEL 5spd.
I hate to break it to you, but if its a DD you should probably stick with whats been done. At least that way when (not if) something goes wrong theres people that can help you out. If your the first to do something when you need help your on your own.
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
PapaBurgundy wrote:Sorry but the mighty max\dodge d50 trans wont bolt up to a 4g63. My brother has a 4g conquest and tried that, it wont happen. But if you can get an adapter plate machined anything bolts up to anything, I know a guy with a 4g conquest thats got a chevy t5 trans.
Theres a guy locally that is running a 6-bolt 4g63 from a 90 GSX in his MM/D50 with no adapter plate. I talked to him a few times about his setup and was intrigued with his project since it not a common swap that I see. He had mentioned that it took awhile for him to find the MM/D50 that would work which had a manual 4g64. Since they are both narrow block configurations they mated up just fine according to what he said. I had thought that the 4g's from Starions/Conquest were wide block configurations and thats why they don't work with 4g64 MM/D50 trannys, as for the 2.6L D50 transmission I have no idea. Not trying to argue or pick a fight just trying to get my facts straight if I'm incorrect. But your right with a adapter plate machined you can mate anything together. There's a couple of eclipse/talon guys talking about using a turbo 2 transmission from a FC3S for a rwd conversion project. Has anyone heard or seen that conversion done?
Wei
PapaBurgundy
Argue away if you like I dont really know that much about it other than like you said it has a lot to do with the wide\narrow block stuff. Oh and the conquest never came with a 4g, just the piece of junk sohc, tbi 2.6 stroker timebomb.
White Comet
Car: fc, s13 and mazda6, Sierra
Wei
havent heard of it, but some fc guys swap to the miata trans
Ice2CU
Car: 1998 240sx
PapaBurgundy wrote:I hate to break it to you, but if its a DD you should probably stick with whats been done. At least that way when (not if) something goes wrong theres people that can help you out. If your the first to do something when you need help your on your own.
Of course that makes the most sense. But the point of this topic is that I wanted to see what people had ideas for putting into a 240, other than the common motors.
anumeric
I wouldn't mind doing a f20 / f22c project in my s13 or ae86 one day when I have more money. There was a thread awhile back of someone who did this swap and I thought it was pretty damn sweet. We
PapaBurgundy
Of course you wouldnt mind an f20\22! Its the god of all na 4 cylinders.
anumeric
PapaBurgundy wrote:Of course you wouldnt mind an f20\22! Its the god of all na 4 cylinders.
I definitely couldn't agree more. Here's a old 71' Celica with a f20c I saw on Grassroots. Now thats sexy car with a sexy motor. Sorry if this is a repost of pics, I think I've seen them on here before.
Wei
brizanden
Car: thrased kouki ftw
lol i lovee how empty tht bay is
PapaBurgundy
Holy crap! Too bad there isnt a smiley face for jerking off, if he had itb's on there it would be better than p0rn.
PapaBurgundy
I've got an idea, the f131 evoluzione! I gaurantee its not been done.
sommmatt
Car: 1989 Nissan 240SX
SHO Swap
datsun2401972
Car: 90 Nissan 240SX XE coupe
PapaBurgundy wrote:Oh and the conquest never came with a 4g, just the piece of junk sohc, tbi 2.6 stroker timebomb.
Didn't the Japanese spec Starion use a 4g?
EviL inside
Car: 90 240sx
Florida240sex wrote:
L28 would be a pita to get into a 240, it's a good bit to long. Also i would think that it being so long would throw off the balance.
http://www.240sxforums.com/for...77182
nice little video of another one that was done,,,check out the throttle response...http://youtube.com/watch?v=3ZOJdVfv8eM
a tight fit, but not TOO long,,,and more room to work on it once it's in than a V8 swap gives.
the way i see it,,,ANYONE can shove a big motor into a little car and make it go fast. in a few years, all the V8 guys are going to be scrambling to get rid of the gas guzzlers that they can't afford to drive anywhere.
at some of the meets, it's funny to watch the L28ET guys run 11's and 10's while the V8 swapped guys are stuck in 12's and higher. but they make lots of noise,,,i give them that!
the S2K motor is a cute little torqueless thing, isn't it? no wonder the diffs break once any forced induction is introduced.
Modified by EviL inside at 1:15 AM 4/30/2008
koroshiya
Car: 1990 pignose Hatch!
rotrary ftw
Ice2CU
Car: 1998 240sx
Wei
that car looks pretty cool. i have never seen anything like it before. and i think that is what we all want to go for: something completely original. I think that is what my problem is. Its too easy to do a typical, easy swap. I want a challenge and something that no one else can say has been done.
Just remembered to think about finding a suzuki cappuccino and having a little fun with that.
PapaBurgundy
I dont think starions ever had 4g's. Not sure but I dont think the 4g63 as we know it was around in 1986-88.
datsun2401972
wikipedia states something about a single cam 4g63 that was used in japanese and australian models...hell, it even states they made a 4wd starion for group B rally before group B was canceled, sounds pretty kickass...
White Comet
yeah well wikipedia also says i **** on eggs
Ice2CU
Car: 1998 240sx
datsun2401972 wrote:wikipedia states something about a single cam 4g63 that was used in japanese and australian models...hell, it even states they made a 4wd starion for group B rally before group B was canceled, sounds pretty kickass...
wasn't Group B the one where the cars didn't need to go into production in order to be qualified to race? I remember that there was a Ford Rally for that group, I think, that had a turbo 4, awd, and killed half the drivers that drove them. I wouldn't doubt that there was a Starion awd.
datsun2401972
White Comet wrote:yeah well wikipedia also says i **** on eggs
Yeh, I guess wikipedia is only as good as the people behind it...
PapaBurgundy
Yes there was a awd starion and the ford your thinking about is the rs200. The reason why everyone got killed and it was cancelled was because there wasnt much for rules so manufacturers made awd cars with over 500hp that weighed less than 2000lbs Recipe for disaster and kick@ss racing.
Ice2CU
Car: 1998 240sx
PapaBurgundy wrote:Yes there was a awd starion and the ford your thinking about is the rs200. The reason why everyone got killed and it was cancelled was because there wasnt much for rules so manufacturers made awd cars with over 500hp that weighed less than 2000lbs Recipe for disaster and kick@ss racing.
I wish they would bring back that formula
PapaBurgundy
Agreed. So I take it no one liked my f131 idea?
morbid
Car: alot of s***
A vq35hr would be nice, and I don't think it's been done before.
Or wait until somebody crashes their 09 GT-R without ruining the engine .... and you can figure out the rest ;-)
datsun2401972
Hell, I didn't even know what an f131 was until about a month ago...
BurritaSVT
Figured I would add a motor to the list since I have already started the build I purchased this motor for $250 and a 2004 Taurus motor with less then 20k miles on it for $450. I will take all the accessories off of the 3.0 Taurus 3.0 splitport motor and add them to the newer 3.0 oval port motor. But before we do the long block swap we will dyno the 99 splitport motor then dyno the oval port. The motor weight less then 300lbs total weight and is built for 450hp potential. We are going to mate it up to the T5 manual transmission in the 240 sx might be one to add to the list expected to finish by this month. Here is a pic of the 3.0 split port duratec perfect for the job
PapaBurgundy
Hmmm.. -1 for being just a little too different, the OP seemed a little more interested in not crappy motors, but maybe I misenterpreted him.
bt2s14
Car: 96 s14 VG30E swap on the way
I'm doing a VG30E swap right now. If you haven't swapped anything before I don't suggest something too crazy.
