SOMEONE HELP PLZ!!!!!!!!
SilverBulletNissan
Car: 2003 Nissan Sentra
My sister has been driving my car for less than a week and she is having all sorts of problems with my 2003 Nissan Sentra Se-R Spec-V and i cant figure out why.... She says that she can shift into 3rd and 5th but has a hell of a time shifting into any other gears.... She also said that she can move through the gears with the car off easily.... And that she has to turn the car off to shift into reverse then turn it off again to go back into first gear.... Im lost.... I have told her to have someone look at it for her but her translation of what the mechanic tells her is very confusing im thinking maybe the shift cables have loosened up.... the transmisson is out of sync somehow.... the clutch going out.... but she didnt say that the clutch was slipping so idk.... someone plz help im loosing my mind!!!!!!
SilverBulletNissan
Oh and i forgot to mention that im 1800 miles away so i cant go look into it.... makes my life hell right now....
aebstract
Car: 09 Sentra SE-R Spec V
Sounds like she doesn't know how to drive it..
SilverBulletNissan
she has been driving with a manual tanny for years though thats the problem or else i wouldnt have let her take it
nametakennow
Car: '06 MINI Cooper S
Hop in and see if you have the same problems.
edit: Nevermind, 1800 miles.
Seems like there were some transmission failures with the first couple of years. Syncros go bad. SOL unless there's a recall on it (I think there was on 02s, but not 03s).
SilverBulletNissan
I hate being in this position.. im helpless i took it in for all the recall things when i got it and through out the time ive owned it... i just dont know what else to suggest to her other than take it to a shop and we all know how that goes....
aebstract
It drove fine before you gave it to her?
Faja
Car: 2009 Nissan Sentra
I would have her take it to a local mechanic and have him check out the actual shifter mechanism - bushings, mount, linkages etc - to rule out that possibility before getting into any transmission issues. You said 3 and 5 are fine so maybe it's just the downward movement that is restricted.
SilverBulletNissan
Well it drove fine for the most part i had to change the MAF sensor before she took it but that has nothing to do with the actual shifting thing and its never had this problem with me.... It was always easy to shift and the dam thing shifted fine...
SilverBulletNissan
oh ya... well i put a short shifter in there a couple years ago maybe the linkage in that whole set up finally wore loose because it has done that to me before... and i did break a shift cable but had that all replaced
ABNRML4U
Car: Nissan B13
It feel's to me it's just a simple problem is all. Just wish her a very Merry X-mass.
aebstract
SilverBulletNissan wrote: It was always easy to shift and the dam thing shifted fine...
Maybe she can't drive it
SilverBulletNissan
PROBLEM FIXED!!!! the braket holding the clutch pedal in place was broke and had to be welded!!!!!!
