some updates for you guys
pejsa s-13
Car: 91 HardBody, 85 720
ok so i tore it down today
out with the old
in with the new (02 supercharged frontier lsd)
the mess that is my garage
my salvation
seang
Car: Ford Fiesta ST
Cool! What ratio is it? I heard that some of the later limited slip units got soft and don't bite like the early ones did. I also read (and if I remember correctly) that you can add discs to it to tighten it up. Perhaps Desert Rat will know more.
pejsa s-13
i have no idea about all that if i put it in and its sloppy ill just have some one help me re-shim it
BronkStang
Car: 06 commander,94 HB Freddie,97 HB autox, 89 Bronco-stang
awesome! i thought our only option was a pathy rear... yeah whats the rearend ratio?
pejsa s-13
no idea but the leaf purches are identical in distance but the over all width is 5/8 of an inch wider
seang
Car: Ford Fiesta ST
Was the new axle from a 2wd or 4wd?
pejsa s-13
yea i just looked at your email, and called the nissan dealership and they told me the 2wd and 4wd versions are no different maybe i got luck and got the early 2002 version that seems the be "more agressive"
if not ill figure something out to remedy this
thank you for that linkk though very insightful
pejsa s-13
k so i notched it today
yes i boxed the frame and plated the top
the exhaust need an "adjustment"
and my gas tank mount ghetto i know but i stood on it and it was pretty sturdy
let me know what you think
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Are you going to re-bush the springs eyes while you are in there?
pejsa s-13
you mean redrill the purches? yes i plan on it
im also gonna change some stuff with my leaf springs
pejsa s-13
redrilled my leaf purches today & let me tell you BIG PITA
Rev_D21
I wouldn't have re-drilled the perches but that's just me. I meant were you going to install new bushings in the leaf pack....ie Energy Suspension?
pejsa s-13
why wouldnt you redrill them?
and yes eventually
Rev_D21
I still use mine as a truck now and then, excessive lowering would hinder that. Plus call me a snobby purist but I just don't trust those kinds of mods.
pejsa s-13
fair enough i understand, this is just a mod ive been waiting to do, and hopefully it come back to biteme in the ....
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
Looks like you're in for a fun time. Love to see it when it's all done.
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
That frontier axle is about 4" wider than what you took out. It should have a 4.636 rear gear if it came from an SC truck. It's all the beef you'll ever need, but it's gonna stick out on the sides.
pejsa s-13
yea i was thinking of something else when i said 5/8" wider cant remember what though.
but yea this rearend is crazy just mounted it yesterday!
almost done ill post pics later today
pejsa s-13
here are some pics for ya
gonna need to roll the fenders
overall width
bed width
Rev_D21
Get some flares, should cover that up nicely. Looks excellent! Is that a Hellwig bar in the back?
pejsa s-13
i think im just gonna roll them with a baseballl bat lol
and no its the stock frontier sb
pejsa s-13
so more progress today
i intalled some new pintos yay
got it back on the ground
heres a picture of my ghetto redrill
got the parking brake mocked up
and now i need a driveshaft, heres what i have to work with
8v fury
Car: 1991 nissan hardbody extended cab
Keep up the good work.
pejsa s-13
thanks well the truck is pretty much done now but i dont like the final product so tearing back down on tuesday
gonna 4 link it and coil over the rear end
for coil overs im gonna be running a pair of yamaha r6 rear shocks lol yea baller on a budget
updates soon
pejsa s-13
oh btw i dont recommend this rear end swap unless you want it to be a trail rig, the gear ratio is horribly low.
and its pretty damn wide too
Rev_D21
Sorry to hear that man. I was wondering about that. I'll stick to my 1wd for now till something better comes along.
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
Have you thought about welding the spider gears in the stock rear end?
I know it is not ideal but, it a cheap solution for a locking diff.
LEMHEAD16
'95 QofDOOM
'56 Chevy pick up
Paint the back of the cab too while you have the bed off. I love your truck btw.
pejsa s-13
yea thats the route im taking now just have to find someone with a good welder to do it......
and good idea =P
pejsa s-13
so me and a buddy started the 3 link today made awesome progress
the lower link bars
the upper wishbone link so far
the lower link installed
the brackets on the pumpkin
the new crossmember
all i need now is two more link end bushings, grade 8 bolts, install my driveshaft, brake lines, weld the upper link together, cut the bed, and but the coilovers lol lots left
