So the fact that its an auto doesn't change the ecu settings? As far as the harness, once the ecu is switched over, is it just plug and play?nissanfreak12 wrote:Since you are going to use the 5 speed, I am assuming its a NA, strong enough, but you will need a stronger clutch. Ort you can get a TT flywheel and TT clutch, get a shim for the starter and grind out the inside of the bellhousing.
Your Z1 ecu should work without a new eprom. But have it in mind if it doesn't work, only thing that would cause issues is the different year chassis.
Swap out the fuel pump, fuel pump controller from the TT.
Don't forget the remove the auto spacer from the crank and replace it with a bushing from a speed. Yes you can use the TT harness, but make sure the plugs are not trash.
Yep, its really that easy. If you swapping a 5 speed in a Auto car, there is more work. But since the car is already a 5 speed, its an easy process.itsa300zx wrote:Plug and play from Auto to Manual, cant go the other way.
