DALAZ_68 wrote:parts needed for S14 engine in S13 chassis
s13 DOHC parts for swap...DistributerIgn Coil and braket assemblyalternatorengine harness (MT)ECUMAFheaders (wiht EGR cooper pipe)temp sensorThrottle body w/ MT TPS (only has one outlet plug to harness
i just finished this exact same swap so i knoe lol
I swapped a 96' KA into my 90 chassis but converted it to an S13 KA24DE first.
I went a bit different of a route than you did;
I had to swap an S13 lower intake plenum. the sensors/harness on the S14 lower plenum do not match up to the S13 engine harness. Since I am going to boost the motor I reused the S14 upper plenum (No butterflies! WOOHOO) You'll need to get a set of intake manifold gaskets for this. Felpro sells a set at Advance Auto Parts for less than $10 as I recall. It is IMPERATIVE that you take your time cleaning off the old gasket on all surfaces, being careful not to score them too much. I have a gasket remover which is basically an angled handle that a razor blade fits into. I cant stress this enough, take your time and do this part right. Your idle will be ****ty and your motor won't run right at all if you have a leak in the intake manifold.
I was able to reuse my SOHC throttle body from my car, it has 2 plugs, one on the housing of the TPS and one on a 3-wire 'cable' leading from the TPS. The engine harness connects to the plug on the 'cable'. I did nothing with/to the plug on the TPS itself.
Distributor, check, Ignition coil, check (used MSD blaster coil instead), Alternator, ECU, MAF, EXHAUST, check.
The only other thing I changed was the throttle cable and made custom coolant hoses to the heater-core. THe SOHC throttle cable is a bit shorter than the DOHC one is and the SOHC heater-core hoses don't match up.
Not sure of the legality of this in your area but I got rid of all of my emissions as well. Makes things 100x simpler. if you must keep them, be sure to replace all of your vacuum hoses while you have to motor out. It's a cheap bit of insurance against stuff running poorly when you get the motor started up. The fewer problems the better in case something isn't working right. Then you have that much less to diagnose.
Obviously your power steering is not going to mate up. I'm running just the bare S14 power steering pump since it's the tensioner for the water pump belt, I cut and created a loop between the lines on the steering rack so that no debris could get in there. It's really not so hard to steer, even while braking and I have J30 front brakes. Unless you are dead set on having power steering this is the route I would suggest, as people want way too much for S13b power steering racks in my opinion, especially for a luxury. Then again this car isn't really my daily driver.
You'll have to cut the brown plug off of your DOHC harness where it connects to the chassis (next to the main ECM SMJ,) and connect the white one from your SOHC harness. It's very simple to wire up, you simply match all of the wires to their like-colored counter parts. You'll have a few left over that don't match, you don't need them. it's that easy. I made a harness for mine since my DOHC harness was cut on the chassis side of the plug.
I may have another resource archived somewhere if you still have questions.
more pics for refrence (yes I cleaned the engine bay and hid the harness while I was at it)
(caution, high res pics, 56k= a dead SOHC motor)
http://img164.imageshack.us/im...0.jpg
http://img389.imageshack.us/im...8.jpg
Modified by Import_Ant at 5:41 AM 10/5/2007
*edit, found the archive for the 95' KA into 89-90 chassis.
http://www.nicoclub.com/articles.php?id=162443
enjoy
Modified by Import_Ant at 5:48 AM 10/5/2007
