sneak peak under my hood
BoostFab
Car: S13cp, S13fb, S14z
it's an rb20 with aftermarket turbo and a top-mount conversion with the stock manifold.
Modified by BoostsFed at 12:48 AM 1/22/2005
Nameless EJ6
Car: What the **** do you think.
Nice!! I wanna know what numbers you're putting out on it.
I usually think of RB20's as a stupid choice.. but with an aftermarket turbo I can see some justification. Good job.
driftjunke
BoostFed looks bad ***, what turbo is that? What size FMIC you running? No aftermarket BOV? What type of fuel and engine management you running?
Inline 6 or Inline 4, Iron block or aluminum block, Sr is generally double the price of the RB, yes if you use mounts, then the motor goes up a little but not that much, yes you have to buy 2 more injectors and spark plugs than the SR, what the RB lacks in wieght, it makes up in torque.
Can't wait to see the numbers.
Eric
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
Looks really nice. That turbo fits so neatly in there.
what are you doing for engine management? considering you are recirculating the BOV, I am just curious if you are using piggy back or stand alone.
93RPS13
Car: Cars, Girls, Cars, Food
"File attachments can only be linked from the message board server; Outside linking is not allowed."
does anyone know why cant i see these pics? its shows that message....omg i wanna see this badass engine
BoostFab
Nameless EJ6 wrote:Nice!! I wanna know what numbers you're putting out on it.
no dyno yet....(not until i get more fuel, 720cc injectors and proper tune).
the turbo is an t04e with .70ar vband on the exhaust side--it hit full boost (15psi) at 4500rpm. i enjoy walking over GT's....not enough to take the Cobras though.
93RPS13 wrote:"File attachments can only be linked from the message board server; Outside linking is not allowed."
lol....nothing to cheer and rave about, just the "crappy rb20"
Modified by BoostsFed at 12:44 AM 1/22/2005
OKCA18DET
BoostsFed wrote: i enjoy walking over GT's....
shouldn't u be doin that anyways with a stock RB20 and the stock turbo?
BoostFab
modified GT's are a bit different.
OKCA18DET
hmm they are 13 second cars,...and so are RB powered 240's..well S13's atleast thats all i've seen run but hey it doesn't matter cuz i like what i see under your hood
BoostFab
true....and thanks!
my clutch is slipping like crazy when it hit full boost....it's time for a new clutch...i'm thinking ACT NX6-HDSS....anyone have experience with this? it's supposed to hold 400lb tq.
goofynick6
Car: 1995 S14.5 RB20DET
All I wanna know is how well does that turbine cover keep the heat from the engine bay and into the turbo? I was really interested in one of those!
Looking good.
Nick
BoostFab
goofynick6 wrote:All I wanna know is how well does that turbine cover keep the heat from the engine bay and into the turbo? I was really interested in one of those!
Looking good.
Nick
it's a "turbo blanket". let's say after a long drive--put your hand on it and won't get burn. dramatically lowers the temp in engine bay.......i recommend you guys to get one of these.
NissanTurboSix
Top mount conversion?
Details! I haven't heard of this before.
240+civic=pimp
Car: s13/rb20det, 2002 WRX, 1994 Yamaha fzr600
I just installed a .63ar t3/t4 in my rb20, did you have fuel problems with your t4?
At 15psi does your car lean out?
I am thinking if i need to buy a afc or bigger injectors?
How much faster is your car than stock?
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
240+civic=pimp wrote:I just installed a .63ar t3/t4 in my rb20, did you have fuel problems with your t4?
You prob have maxed out the stock injectors. They are only 270cc. Bigger ones will be needed to make some good power with your new turbo.
240+civic=pimp
Can you fit a t3/t4 with the stock manifold in the low position?
otherwise how did you use the stock manifold to make it that high?
BoostFab
NissanTurboSix wrote:Top mount conversion?
i custom made an adapter works well until i have time to make a tubular one.
i'm runny lean, i have 720cc on the way....and a better tune, i'm looking toward 400whp goal with this setup....run it until it break, because i have another rb25 long block sitting here waiting for boost
240+civic=pimp wrote:Can you fit a t3/t4 with the stock manifold in the low position?
i made a top mount adapter....that's how the turbo sit with it on there. the stock mount location will fit a t04e just fine.
StricNyne
that loooks rly nice man, i am going to a massive thought process of what i want to do regarding turbo wise, i would like a t4, but am worried about lag issues, i have a 25 btw
BoostFab
StricNyne wrote:that loooks rly nice man, i am going to a massive thought process of what i want to do regarding turbo wise, i would like a t4, but am worried about lag issues, i have a 25 btw
thanks! the 25 will spool it faster.
i will be getting rid of the upper stock L charge pipe along with the stock BOV....it's just too heatsoaked
JonPowell
Car: Cars, Music, My family
Everything looks real nice except one detail.....your radiator isnt bolted in on the top???
Andrew85cm
Car: 89 240sx with RB20det
Please give us some more detailed description of that adapter. I would like to do something similar. Could you take a picture or something of the actual adapter. I was going to make a adapter box anyway mine as well make a topmount. Was it too hard to fab up. I imagine you are running the wastegate off that flange. That looks like a sweet install. It will be good to see some dyno numbers.
Aren't 720cc injectors a bit too large for your power goals especially when you will be tossing the motor when it goes. I hear the hp numbers are equivalent to the size injectors you need. So for 400 hp you could get by with 450-550 injectors. That would be ample. What kind of kind of engine management are you running?
