I ran the ECU and everything is fine, code 55rgregoryb wrote:First of all you need to run the ECU codes for a starting point.
Im pretty good and being able to pick up on coolant, i have not been able to smell any lately but my first assumption was that there was some type of leak. I have only had the car for a little under a year so i am not 100% sure when the timing belt was done, but there was a nice stack of service records i can look through. I replaced the fuel filter at the time of the tuneup. My mechanic did mention that the hoses were old and brittle...elecfus wrote:your mechanic probably did a radiator pressure test on the car. this test involves removing the radiator cap and applying pressure to the coolant system. they then watch a gauge to see if the pressure drops. if it drops then there is a leak. they also would have done a visual inspection on the coolant. you cant tell by looking through the top but if you remove the lower radiator hose and collect it in a tray you can see if your coolant is old and full of rust. it wont be a bright red or green color if so. it turns yellow or brown depending on the engine content of the water. check around the edges of the head gasket, where the heads meet the block. if there is black sludge there then your head gasket is leaking.
it might not be the radiator but there is a coolant leak. your engine is overheating. dont drive it.
the pinging or ticking sound and rough idle are your heads being warped out of shape. engines often recover mostly once the cooling system is repaired.
when was the last timing belt and water pump kit done? the service interval is 105k km although people often leave them longer. your 150 000 milage indicates that it was due for its next timing belt kit a while ago. look around the inside of the bonnet, engine or windshield for a sticker saying when it was last done. with an overheating engine it's a good idea to go ahead and do a timing belt, roller and pump kit along with the hydraulic bearing in the fan. get a good kit like a gates, dunlop or denso. fancy after market brands tend to use cheap chinese replicas which may or may not last the whole interval. its only a few dollars more and will last you the rest of the life of the car. you can inspect the timing belt by openning the little 1" wide circular flap on the timing belt cover, that big black plastic thing behind the serpentine belt. worn belts dont always show wear but if there is visible wear then it is long overdue. take a photo for us.
you should also look into replacing all the coolant hoses because overheated coolant stresses the rubber and causes leaks. start sourcing the hoses. here in australia, some of the hoses were strange sizes so I had to use metric oil and transmission lines and $40/m hydralic hoses for the AIV system. it's OK to use nitrile hoses where EPDM rubber is used because nitrile is stronger and more resistant. oil will eat through EPDM and burst the low pressure rated water hoses though. make sure you get hoses that will fit over the barbs as high pressure rated hoses wont stretch like un-reinforced water lines.
This will make me sound like a total noobie, but what is the difficulty level for replacing the radiator? I have not had much hands on with my car...evildky wrote:I'd start by replacing the known bad radiator, there are small coolant lines running under the plenum, most likely one of them sprung a leak, you can bypass them but continuing to drive a car that had a bad radiator is asking for trouble.
