nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Fri May 20, 2016 6:28 pm
You can contact conceptzperforamnce, Z1, or specialty Z. Ask them if you need a tune for the JWT cams, I am not 100% sure if you do, but it will make a good difference.
As Evil said with the timing, did you do it or have it done? IS your ignition timing set at 13° +/- 2°? Did you just rely on the marks for the timing belt or did you actually count the cogs?
