Slow cranking.
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
integradude19
Car: 1979 Datsun 620
1988 Supra Turbo
2004 350z Track
Hello. I have a 1979 620 with an L20B. It hasn't been started in about five years. I have cleaned all grounds and connections. My starter has been load tested and is good. I bypassed the battery and hooked jumper cables hot side directly to starter and ground side to the block ground behind fuel pump. When cranking it acts as if it has not enough power. Cranks very slow and resricted for about half a rotation and then barely turns another half turn another have rotatation then barely turns and so on. This continues to repeat over and over. If I remove at least two spark plugs it cranks as if normal. Any ideas? Thank you. Alex
PEZi
well i was gonna say that there may not be quite enough lubrication after 5 years to crank properly and possibly a little seizing... but the spark plug thing is confusing
integradude19
1988 Supra Turbo
2004 350z Track
That was my first thought too. But the oil is brand new also. The oil that came out was clean too. I think my starter is faulty even though it passed the load test.
strollpatrol620
Car: 76' 620 long bed, 85' 720 nap-z
try using a stronger battery, and if it still does it hook up some jumper cables to the battey and to another car while its running and try that out. My truck does the same thing, not enough amerage will cause that problem, it means even though the starter has been load tested the starter may need to be rebuilt due to dirty brushes within the starter.
integradude19
1988 Supra Turbo
2004 350z Track
I haven't used a bettery at all. Always jumper cables to a truck that is running. So I know it has plenty of power. I'm just going to get my starter rebuilt or get a new one and see how it goes. I also am going to take the plugs out and turn the motor by hand and see if its very restrictive. Maybe seized bearings?
Return to “Datsun 620”
