attofarad »
https://forums.nicoclub.com/attofarad-u73688.html
Sat Feb 19, 2022 1:01 am
On a January trip, I noticed that the 2001 QX4 brakes seemed not so great, pedal a bit soft, travel a bit excessive. Getting a bit worse. I decide to lube/adjust the rear drums, since I read somewhere that unadjusted rears could give more brake pedal travel. I was due to do that anyway. I flushed the brake fluid while I was at it (had been 3 years). After that, brakes were slightly worse and quickly got really bad. Re-bled brakes, getting no air and no improvement. Unhooked lines at master cylinder, plugged the ports, and got a good firm pedal, with expected action engine on and off -- so both master cylinder and booster seem okay.
So, it seems that I am down to a bad ABS module. I don't even see how to get access to the bracket below the module, which holds it in. Super tight space to get to heat shield bolts, then bracket underneath that.
Any other ideas what else could be wrong, or is time to say goodbye to the QX4?
