The things I'd check to see if your ignitor is bad or a bad CAS. I was running SOHC engine bay harness with the CA18 Engine harness with no problems. check out this webiste and see if you forgot to wire any of these wires since there is a few specific wires that run your ignition. This is for an SR swap guide but the wiring is almost the exact same for CA.
http://www.frsport.com/SR20DET....html
Also on the CA18 engine bay fuse panel it has this with actually 6 relays(one being empty N&P) but it doesn't seem to matter if the ignition location relay is empty on the SOHC harness for some reason it works without it.
Modified by chausaster at 2:02 PM 7/20/2008
Modified by chausaster at 2:05 PM 7/20/2008
Modified by chausaster at 2:08 PM 7/20/2008
