SidePipes
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Bloodman324
Car: 1981 Datsun 720 Kingcab 2WD Automatic
Ive found a set of side pipes that i wanna put on my truck for around 200 bucks, are there any problems i might run into with putting these on? http://www.summitracing.com/parts/PTE-H1060/?rtype=10
woodbutcher5691
Car: 85 720 2wd 5sp.
3- 280zx's
Burnt leg getting out of your truck? :laugh: :poke:
Davezilla
Car: 1990 300ZX
1986 720 4x4
You may run into some clearance problems putting them on a 2wd but it can still be done... I've seen it done on a mustang where the pipes were looped back to the front to mount up to the side pipe inlets. With a 4 cyl engine that only has one outlet tho you'll either need to run a splitter or get a single inlet dual outlet muffler so both sides will be functional. They also sell those pre bent pipes that you can cut to fit then either clamp them up or have a shop weld them for you... unless you have a welder which would be the best way to do it.
All the good performance muffler brands make a single inlet dual outlet version of their mufflers so you can pretty much pick and choose for the sound you want or you can just run a glass pack then add a splitter to send the exhaust to the pipe inlets.
Either way, if you do a total DIY to get them to fit and work it'll take some work to do or expect to pay a shop a few bills and they can fit it up for you.
Bloodman324
Haha good one woodbutcher, and ah i see, i knew i needed a splitter, but wasnt sure if there were gonna be any major complications with it. What i think ill do is take my existing glass pack, move it to the front and use a splitter to connect both pipes. Thanks for the help, ill keep you guys posted on my progress. still got to get new brakes yet lol
woodbutcher5691
3- 280zx's
Yea, good brakes will be a good investment. Ain't nothing like hauling azz and then all of a sudden,............. "$hit I got NO brakes!" :ohno:
Davezilla
Car: 1990 300ZX
1986 720 4x4
Ugh... same here... mine came to a rumbling stop the other day but luckily I was close to home so it didn't toast my rotors too badly... I hope. :ohno:
Bloodman324
Ya no kidding! Thatd be some scary s*** right there, then you'll prolly end up totaling your truck depending on the circumstances, and thats not something i wanna do. And at least you were close to home when that happened davezilla, hope you didnt do much damage to them rotors.
Return to “Datsun 720”
