chompsticks »
https://forums.nicoclub.com/chompsticks-u140901.html
Sat Jun 18, 2011 8:35 pm
So I have had the AVS in-channel deflectors for a while and decided to switch it up and get the Nissan factory deflectors. I will just say this. If you are looking for them, get the Genuine Nissan deflectors. They are ten times nicer, stiffer, sturdier, smoother and quieter than the AVS in-channels, which are flexible because the double sided tape is mounted to the rubber window seal and not cut smoothly.
The only drawback to Nissans deflectors is that you have to mount them to the paint.
