DCaff300ZX »
https://forums.nicoclub.com/dcaff300zx-u136230.html
Fri Jun 05, 2015 9:42 pm
First off, we need to know where you are located to have any chance to perhaps know of a qualified Z32 mechanic.
Next, losing the wheel liner in such a way hints at the chance the air intake was also damaged and/or the air box, or that the air box was dislodged/damaged to expose the MAF.
Having air flow across it can cause such an issue as you indicate, although there are other possibilities that would be diagnosed best if there are any ECU codes/check engine light on.
If you are mechanically inclined enough to change the air filters, then you can check to see if this is your problem and perhaps avoid a trip to a Nissan dealer at worst, or a Z mechanic.
If you can, when you unbolt the front cowl cover to expose the filter box assembly be sure that the box is undamaged and it is in it's correct place, and that the two "arms" extending into the wheel wells in front are also in place and one not perhaps jammed into the air box.
Your solution if there is damage or otherwise an exposed MAF may be to find a way to replace the air box correctly, and have the MAF unit inside the box be sealed from the outside airflow.
Hope this helps, and that if you post your location we can suggest a Z32 mechanic if needed.
