shut off while driving.
victormotorsports
Car: 90 NISSAN 240 SX, 01 lexus IS 300, 06 acura mdx, 01 honda cbr 929rr
96 nissan maxima se, while driving in stop and go traffic car shuts off out of no where, with out warning. But starts right back up must rev it up a few times for it to stay running then runs fine for a while then does it again.
pm_page6776
Car: 2009 A/C 2.5S
Most common issue i have seen in maximas are mass airflow sensors
victormotorsports
how can I check it if it's bad?
carmo
Car: 92 Accord, 90 Civic, 89 240sx
No check really. Do you have a CONSULT1? Me neither. Usually an airflow meter won't cause a car to shut off out of nowhere. When airflow meters go bad they tend to cause the car to run like crap for a minute then shut off. If thats your problem, then yea, airflow meter is a possibility. Maybe Air intake valve for your idle speed control. I have seen, on those maximas in particular, the AIV valve or the control unit take each other out. You'll end up having to replace both at the same time. It's uncertain whether to say which has gone bad first. However, usually in that case, the idle is high and will not come down. Don't overlook this aspect. You may try to go to the dealership and have them do a "function test" of the Idle Air Valve, with CONSULT1 or 2 (which ever plug it is), and see if all goes well. If not, you may be on to something.
victormotorsports
what about map sensor?
carmo
No MAP sensor on those vehicles. I've only ever seen cars have one or the other, MAF or MAP.
victormotorsports
Well i got car fixed it was mass airflow sensor crazy huh? was for me and expensive.
carmo
Cool. Sorry if I steered you in the wrong direction. I'm glad it was simple.
