Thanks for the reply. Interesting that you felt no difference with shocks that had 120k on them - I would definitely think replacing at that mileage would have made a difference, unless the roads are super smooth where you live, LOL.Eric. wrote: ↑Thu Oct 22, 2020 8:54 amThis doesn't apply to specifically the EX, but at 120k, I replaced the shocks on my old V36 2007 G35S (this was 2018?). No particular reason besides boredom/it was old. The originals were fine, and there was no difference when I put on the 30k used OEM replacement shocks. I was surprised. What did need replacing were both lower front control arms. I went with Beck/Arnley on those, as they were 1/2 the price of Nissan parts. It's not a horrible DIY, at least on a RWD G. Clunking tipped me off for those. I did the swaybar endlinks as well, but the originals turned out to be fine. If you do replace those, get OEM. The aftermarket options, at least the Moogs that I used, needed to be greased every 5k or so. Otherwise they'd pop and clunk.
Anyway, this leads me to believe that the OEM suspension components on these cars are pretty good. That said, the QX is 500lbs+ heavier, so it may be less kind.
Interesting suggestion, but this is just for a car for my daughters, which is used for driving to/from school and around town, etc. Doesn't need anything fancy - just trying to keep costs contained and have it ride close to what it did when new.Jaymes wrote: ↑Sat Oct 24, 2020 10:50 pmThis might be a little bit out there, but why not upgrade to some air suspension for that maximum comfort? I know people install it on cars for lowriding/showing off but the comfort factor is what I find to be valuable. I'm looking into doing this as well for my 17 qx50 since I drive on some bumpy roads for a couple hours a day for work.
Gotcha. I would look on eBay as I see a lot of parts for our cars from totaled vehicles. Many of them come with warranty.sherwooa wrote: ↑Sun Oct 25, 2020 9:15 amInteresting suggestion, but this is just for a car for my daughters, which is used for driving to/from school and around town, etc. Doesn't need anything fancy - just trying to keep costs contained and have it ride close to what it did when new.Jaymes wrote: ↑Sat Oct 24, 2020 10:50 pmThis might be a little bit out there, but why not upgrade to some air suspension for that maximum comfort? I know people install it on cars for lowriding/showing off but the comfort factor is what I find to be valuable. I'm looking into doing this as well for my 17 qx50 since I drive on some bumpy roads for a couple hours a day for work.
Thanks. Fortunately, the KYB shocks and mounts from Rockauto are pretty cheap as it is, but I'm just wondering if anyone's had experience with the front ones and whether they noticed any big difference from OEM.
Awesome. Thanks for the reply. That helps a lot. Did you replace them yourself? Any tricks with the fronts?hercule33 wrote: ↑Sun Nov 01, 2020 9:06 amInstalled both front and rear KYB shocks/struts at 128k a few days ago and there is a huge difference in ride. Small and big bumps are much better damped. I can’t speak for just the front shocks but for me replacing all’s shocks at 128k was totally worth it.
Would you say it’s more comfortable than oem? My 17 qx50 felt comfortable in the beginning but now it feels rocky. Like I feel every bump on the road.hercule33 wrote: ↑Sun Nov 01, 2020 9:06 amInstalled both front and rear KYB shocks/struts at 128k a few days ago and there is a huge difference in ride. Small and big bumps are much better damped. I can’t speak for just the front shocks but for me replacing all’s shocks at 128k was totally worth it.
