MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Wed Apr 16, 2008 1:32 am
Won't hurt anything unless you over-rev the motor and are smart with it (as you would be with a manual)
Downshifting is fine, too. Auto transmissions will only go into gear when they feel like it's "safe." For instance, if you move the lever to 1st at 75mph, the transmission will ignore you (I don't suggest trying this, though, just in case).
Manually shifting (or, rather, as it really is: manually dictating the highest gear you want the car to be able to choose) can be useful in a lot of situations. There's a reason a large number of modern automatic transmissions have with a manual shift mode.
My car's transmission is severely retarded (doesn't always drop into 1st after a full stop which means accelerating anemically in 2nd, doesn't respond to WOT like it should...) so I manually shift mine a lot of the time. It does not slip and is fine mechanically, but I'm also not stupid with it. I keep it in the gear I need when I need to and let it do it's thing when I don't. And I'd say it's a safe bet that my transmission is a lot weaker than the one in the Versa.
