Shifter tuck AHHHHH!!
TLVespasian
Just as the title said. 90 2+2 auto...I cant get the shifter out of park...Im thinking it may be a fuse since the "light" warning is on but there is no kicl panel. All lights work though & it shifted fine a few days ago. Went to move it so the plow could come through & it said "Nah I like this spot." any ideas?
Modified by TLVespasian at 12:17 AM 2/10/2010
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
most auto's have a release hole near the shifter where you can stick a key to disengage the saftey lock (sorry not sure if the Z32 has this for sure but most cars of this vintage do)
most likely the issue is int he ignition switch of the release cable
TLVespasian
No. No release on the z32. This is peeving me off. It was find till a coulple days ago...
TLVespasian
Nothing?? Someone had to have had a similar problem. Anything?!
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
There is a kick panel, it's just hard to get to. Also, I'd check your "Shift Lock" fuse in the engine bay. If that's not it, the brake switch may not be releasing the pushbutton. That's pretty much all I can think of.
TLVespasian
Any info on the location of the shift lock release, what are u saying about the kickpanel? I don't see anything under the brake pedal & the carpet is already out
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Past the dead pedal on the left there is a small fuse box, slide the cover up and it'll pop off. I don't know if there are any AT fuses in there, but that's the fuse box in the kick panel.
The brake switches are above the brake pedal, shown here:
TLVespasian
Thanks. I did find out wht the problem was...............................................................................................................................
........................................................you ready for this...............................................................................................................................................................................................................................................................................................................
PENNIES! 3 to be exact, stuck up in the shifter somehow.....i. unbolted the handle & the plate lifted it up & out they came.....wow....
fowlladyZ
Car: 1990 300zx
i was redoing my interior and saw pennies under my auto shifter too.... i have no idea how they got there but they didnt cause me any problems so ya i just dont know
Ace2cool
Pennies, dimes, ect... are small enough to slide between the shifter trim and the sliding plastic on the base of the shifter and then fall off into the interior panels. Yours must have fallen just right as to cause your shifter to stick.
