Glad we could help (j/k). Amazing that a burnt bulb can cause the transmission not to shift.BOUDREAUX wrote:PROBLEM SOLVED: One of my 1157 bulbs had its contacts arc welded (typical Q) to each other causing the circuit to over load and blow the stop fuse, illumination fuse and shift/lock fuse. Boudreaux
OEM bulb?BOUDREAUX wrote:PROBLEM SOLVED: One of my 1157 bulbs had its contacts arc welded (typical Q) to each other causing the circuit to over load and blow the stop fuse, illumination fuse and shift/lock fuse.
