shifter shakes alot is that normal
konaboy
i have a95 240sx se m/t. when i got the car i traded a 300zx in on it.i noticed shifter shaked alot is that normal.it also does not like run under 3000RPM is that normal.
MainEvent212
Car: 95 Nissan 240SX SE w/ SR20DET+goodies
mine does that too...i think we have similar problems, cuz it's definately not normal
konaboy
what up? when bought the i told dealer that did not like so he told me he put anew tran mont. but still has problem. he also sold me the car with no air intake ,i think he got a action and someone took the cold intake off.
Taylor_Durdan
the motor mounts and transmission mount more than likely are worn out. the transmission mount doesnt exactly dampen the side to side rocking of the motor/transmission, it just supports the assembly. the motor mounts are what prevents the side to side rocking.
id say bad motor mounts.
ninjak84
Car: S13, Z32, Titan
Having your car idle and run at no less than 3000rpms is brutal.Try fiddling with your idle.
lagvoid
I'm experiencing the same thing. Besides the alignment being really off thats the only thing that makes the car feel like a pos! When I'm idle'ing and I tap the throttle and let go I can see the shifter vibrating with the engine.
BrownEyedTrouble
Car: Cars, bikes, and parties.
I had the same problem in my S2000, it turned out to be that the timing was off.
sr20power
Car: S14 Zenki
i just bought a 95 240....and when i was driving her home i noticed that at 75 mph, it was bobbing up and down...i'm having my mechanic look at her, i assume the transmission mounts are worn .....but i'll let you guys know....
stepchow
Car: cars cars cars!
Actually, the shifter bobble is normal because of our direct linkage system. Most cars nowadays are using a cable linkage rather than a direct linkage due to the consumer demand of decrease NVH. Many purists consider the direct linkage to be superior (although at the expense of NVH) due to the fact that u cannot "bind" a direct linkage system when shifting hard and fast. Trust me.....the wobble is normal. When I bought my car back in 1998, it was shipped from Japan with less than 3kms on it and the thing wobbled. Hope this makes sense!
Stephen Chow, MD1998 240sx LE (CAI, ZEX nitrous, UR pulley, Eibach Prokits, OBX shortshifter)2001 Pathfinder SE2001 Honda CBR600 F4i
