boker240 »
https://forums.nicoclub.com/boker240-u85310.html
Sun Jan 20, 2008 3:07 pm
if it staightens out upon braking its not a rotor,if the rotor was warped it w/ do it on braking also. check ur lower ball joint and the tire , could b a broken belt in ur tire, also rub ur hand over the tire ,see if its choppy on inside or outside,itll b like little flat spots every 2 inches or so.
