SFL: 1996 Nissan 240sx LSx 4l80e Turbo Daily Driver
Buy or sell Nissan / Datsun cars, trucks, SUV's and crossover Vehicles!
kingtal0n
Car: 240sx
Postby kingtal0n » Mon Apr 22, 2019 6:08 am
Contact: *REDACTED*
Price $20,000 obo
A silent daily driver with every detail documented (build threads)
https://www.corvetteforum.com/forums/ot ... udget.html
http://www.freshalloy.com/showthread.ph ... nking-quot
https://www.yellowbullet.com/forum/show ... ?t=2559833
5.3 "LSx", Turbocharged, 4l80e
☼ easy to work on for novices and lazy people like me that just have hand tools and no garage (I'm just a student)
♥ anti seize V-bands on proven cast manifolds, fully V-band exhaust is durable and speedy
♥ removable core support via 4x stainless hidden bolts
♥ 4l80e can be pulled under the car without removing engine
♥ bell housing bolts are easy to access with regular hand tools (no extension / air necessary)
♥ excellent spark plug access, 30 minutes to change all eight plugs
♥ 411 PCM runs flex fuel up to 240lb/hr injector, and has real time transmission map switching
-Torque management makes it safe to drive even in the rain, no tire spin shifts at the push of a button
Reliable parts
⌂ original 9:1 engine w/ refreshed heads/guides/seat work/springs/front&rear seals rdy for service to 72lb/min
⌂ 32-spline axles, 3.5:1 rear gear from Q45/300ZX is the strongest OEM diff solution for 240sx
⌂ legendary 4l80e has been seen holding a [email protected] at 3500lbs, it came from behind a 7L diesel engine in a 6500lb truck the legends say.
When you try to shift 4l80e transmission, it shifts you instead.
A work in progress but the hard parts are done. New Z-rated tires for safety. Water is plumbed open loop to several areas in the engine bay and bell-housing for auxiliary cooling to prevent heat soak. Water/methanol injection will raise the octane and lower Exhaust gas temperature to below 1300*F to make it safe to street full power during the hottest parts of the day.
All wiring done using OEM fuse box junctions to maximize reliability, comes with a complete schematic, diagrams bible for every fuse and wire, and unique security/timer features not seen in any other car.
Who is this car for:
You want the power/weight of a Z06 corvette but not the price tag or attention
You are sick of paying for expensive engines that fail rapidly, need something reliable
You need a reliable daily driver that has around 700 horsepower and is also cheap and easy to maintain/fix
Before building this car I performed statistical analysis for several years to select this exact configuration as the best of the best. Currently, this is the most affordable 700hp combination in the world to maintain and the most reliable OEM style drivetrain available at this power level, with these chosen parts.
Reason: CLOSED
kingtal0n
Car: 240sx
Re: SFL: 1996 Nissan 240sx LSx 4l80e Turbo Daily Driver
Postby kingtal0n » Mon Apr 22, 2019 6:16 am
Tons more pics in build threads above, and be sure to ask for latest pics because I make changes every week!
steel30coupe
Car: 1990 240
Postby steel30coupe » Thu Sep 05, 2019 5:42 pm
Congrats on what looks to be a very nice build
kingtal0n
Car: 240sx
Postby kingtal0n » Mon Sep 09, 2019 4:06 pm
I'm driving it everywhere. Camshaft is done, almost ready for what comes next.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2012 Honda CR-V LX
Postby Rogue One » Wed Feb 05, 2020 7:25 am
:poke: What's the status on this? Should the thread be closed? :gotme
PalmerWMD
Car: 2004 350Z
Postby PalmerWMD » Wed Feb 05, 2020 1:52 pm
Hotness!
Return to “Nissan For Sale”
