Well the service manual calls for 0.3V-0.7V for the TPS, but there was a TSB released that uses feeler gauges and ohms to set it. I am testing directly on the TPS sensor using pins 5 and 6 on the CTPS side.
Here's the link:
http://lyberty.com/car/Maxima_A32_docs/ ... 9-053b.pdf
I saw a video over at NPORA by a member on setting it using the TSB instructions. This individual also does not get "O" or "OL" readings as stated in the TSB, but gets low ohm reading using the 0.012 feeler gauge and a reading of "1" using the 0.016 feeler gauge. This individual states that this is the correct adjustments.
When I put back on the old TPS this evening and adjusted it, using the 0.012 feeler gauge I got a reading of 16.9 ohms and a reading of "1" using the 0.016 feeler gauge. Similar to the NPORA member and the TPS is relatively centered in the end. However, using the new TPS sensor, I get the "1" reading using the 0.016 feeler gauge, but the 0.012 feeler gauge ends up showing a reading of 145 ohms. And with the new TPS with those readings it ends up being about all the way on one side almost.
https://imgur.com/a/SwlhUaD
With the adjustments made back to the old sensor and the throttle position sensor idle position memory reset by cycling the key, vehicle is operating properly. It was also operating fine after using the new sensor too, so I'm not sure what's up with the adjustment measurements.
Could the new sensor be wacky or because it is new it will read differently than the old one?
I'm sorry if all of this is not making sense but I am trying the explain the best way I can based of what I am experiencing by following the TSB.
