jltibbs »
https://forums.nicoclub.com/jltibbs-u32412.html
Mon Feb 12, 2007 2:03 am
you should only have three :Bank one sensor one (coming off exhaust manifold in back of engine)Bank two sensor one (coming off eshaust manifold in front of engine)Bank one sensor two (behind or in catalytic converter)
in the instance that you have four (meaning two behind the cat) then you have california emissions and not federal emissions and by the way, it wont damage anything. you'll just start losing gas mileage until you get it fixed. once you replace the O2 Sensor, go to advance auto parts to have the code cleared. keep in mind that if you ask us to do that that we put the code scanner on there and you are supposed to hit the final button that clears the codes. that will just keep us out of trouble.
