service engine light
Home of the Nissan Cube forum and CubeDriver.com
bigjcvegas
Car: 2009 nissan cube 1.8 automatic,..pearl white
Well i took the cube into nissan cause the service light came on,turns out it was a bad bypass valve,they also replaced the rear door handles,and i also had them change the oil,so they would quit calling me every week saying its been over 6 months since i purchased the vehicle,i only have 1162 miles on it,..maybe i need to drive it more.
BORG
Car: Nissan Cube 1.8SL CVT
What up dude? From Vegas also, up in the Reno area. Got anything done to your Cube?
damian666robin
hey what,s up with that rear door handle thingy?i been hearing a lot of cubers got this done because of a weird recall but mine is been working just fine
KromCube
Car: 2009 Nissan Cube Krom
Its not that the handles are not working, they just replace them with more "robust" handles. They're a little more solid feeling.
Rand0m0sityxX
Car: 2015 Nissan Quest S
2018 Nissan Versa S
bigjcvegas wrote:Well i took the cube into nissan cause the service light came on,turns out it was a bad bypass valve,they also replaced the rear door handles,and i also had them change the oil,so they would quit calling me every week saying its been over 6 months since i purchased the vehicle,i only have 1162 miles on it,..maybe i need to drive it more.
If you don't drive alot, then go by months. if its been 3 months since an oil change, change it even if your not to the mileage.
Return to “Cube Forum”
