NASCARLANCE »
https://forums.nicoclub.com/nascarlance-u25867.html
Sun Mar 08, 2009 12:10 pm
First off let me compliment you on owning a very clean and good looking J.I feel your pain. Two weeks ago I was on the Interstate and heard the dreaded "PWOP" on the windshield. A quick scan of my front glass revealed the little star pattern with a 3 or 4 inch leg already growing from it. By the time I got to where I was going the leg had grown to about 6 inches and by the next morning it was about 10 inches.So I had to replace my windshield and I was expecting 5 or 6 hundred dollars. To my surprise it was only $251 installed with a 12 month replacement warranty covering everything and like a 10 year warranty on leakage.You can call and get quotes, I'm sure with you being in the Dallas area you will have many choices as to where to get it done.You need to keep in mind though that your rear window is tinted, has a defroster and has an antenna. This could cause sticker shock when you first get your quotes.Make sure when you get your quotes that you are comparing apples to apples. One place might give you the lowest quote, only for you to find out that the window has no tinting, antenna or a defroster.Good luck and take advantage of the garage,Lance
