djtorello »
https://forums.nicoclub.com/djtorello-u90321.html
Fri Apr 02, 2010 3:51 pm
Sorry i dont believe i have pics of the process.
to remove the front door panals, you will need a flathead screw driver, and philips head screw driver, and a 10mm ratchet.
1) remove the little panal behind the door handle and remove the screw.
2) remove the little panal and screw behind door lock.
3) pull the mirror cover off with flathead screw driver, it will pop right out.
4) Remove window switch panal with flathead screw driver, and carefully remove the wiring connectors.
5) Behind the switch panal is a 10mm bolt head, remove the bolt.
6) Place hands along bottom of door panal and pull. its not hard, and will pop right off.
7) lift up at top of door to remove edge where it meets window.
thats it. just reverse order when your done.
BTW little hint. the door handle has 2 cords going to them, they pop right out if you need to remove panal completely. when you reinstall panal, make sure those cables are where they belong, or you may find out later that inner door handle wont work, but exterior one does. I did that once.
