mdmellott wrote: ↑Fri Aug 19, 2022 7:20 pm
Finkle wrote: ↑Fri Aug 19, 2022 6:47 pm
Well boys, I’m trying this next week to see what they say all these years later. I’ll report back.
If you're looking to see what they say about honoring a warranty like this when you are not the original owner, then good luck. A few years back I found a solution to this common problem that has nothing to do with the recoil spring. Although the spring can likely get weaker over many years of use, I found that the stiffness of the seatbelt strap to be the most common cause of the belt not completely retracting after you unbuckle it. Over the years dirt and grime build up on and within the fabric of the seatbelt, making it stiffer, and that keeps it from retracting. I soaked my belt in hot soapy water and worked it like my great grandma did with clothes on a washboard. Rinsed it well to get all the soap out of the tightly woven fabric of the belt and then let it dry, never letting it retract at anytime during this wash and dry chore. The belt was then as supple and flexible as a new belt and worked good as new when it then retracted completely on its own.
Interesting. I'm cursed with the exxxxxxtra slow retraction on my '03 Q. I did give them a wash once to zero effect. Not a bit of difference. Perhaps not well enough, I can't say. I then gave them a spray with some Teflon dry lube and they were better. For a while.
Spring tension is not the problem, there's plenty to pull them back in, it's going over the D ring that's the problem. I hadn't associated it with stiffness, I initially suspected a stickyness from dirt accumulation over the years, but my cleaning didn't help. I didn't remove it from the car, but did feel like I did a pretty good job of cleaning. Perhaps not, IDK. I might try it again, or maybe just more teflon spray. But it is a PITA.
