SDS Standalone
1SlowCA18DET
With the sds do they supply a base map or do you have to do it yourself?
float_6969
When you order it, they will ask you some questions about your motor and your modifications. I assume that they set it up so that it will at least start and run. Mine did anyway. After I got my coilpack situation sorted out and all of my injectors firing, it started right up w/o a problem.
