salterracingengines is bulding my ca18et
noob2nissan-s12
Car: 1984 200sx turbo
after careful consideration i decided to let my teacher build my engine for me. http://www.salterracingengines.com
im still considering on wheather set the piston bore to hold more boost or not.. the only problem is that i dont think anyone makes the copper head gasket for this thing. do anyone know if there is a manufacturer that does?
salter can do the machining, but let me know..
boost_boy
noob2nissan-s12 wrote:after careful consideration i decided to let my teacher build my engine for me. http://www.salterracingengines.com
If you really need a copper headgasket, I can help. Let me know if you're serious and I'll drop you an email.
Dee
RS12Turbo
Check cs12....seems like I remember reading that a few people used ca-det head gaskets with no probs
noob2nissan-s12
boost_boy wrote:If you really need a copper headgasket, I can help. Let me know if you're serious and I'll drop you an email.
Dee
im serious about the copper gasket. head gasket also needs to have a .036 stainless wire to seal the piston and hold the boost and the only draw back is if its not done correcly water will leak.
yes im very interesting and i want to do everything right for this engine...
noob2nissan-s12
RS12Turbo wrote:Check cs12....seems like I remember reading that a few people used ca-det head gaskets with no probs
are you talking about in nico forums?
RS12Turbo
IggyEGuana
Car: 1986 200SX S12
Thats affirm on the ca18det HGs. Works perfectly on the singe cams.
IMO OEM HG and proper torque spec/sequence/retorque is all you need
mod_mastaz
Cometic makes a copper HG. Another S12 member is also going to use that in his ET build. Look into DE/DET rods as an upgrade for the ET also.
