float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Tue Jul 26, 2005 2:50 am
This has been talked about a lot, and the answer to your question lies on a dyno. I feel that the injectors are the limiting factor in your setup right now, as they are only safe to about 245-255hp at the wheels. Even that isn't accurate due to not knowing how well the ECU is tuned. To safely tell you need to get the car on a dyno w/a wideband.
