safc2 question
1SlowCA18DET
i just wanna know how accurate the knock reading on the safc2 is?
Loofee95SE
Car: u gota sister??
not very...
capwred
i dont think its all that correct myself.on mine it dosent read nothing to after you drive the car for about 45 mins.then at idle it reads about 5 and when you start going it reads 0.so dont know if anyone else is doing the same but i dont know what swrong.
burnout 180
Car: 1990 s13 180sx ca18det
what does the knock sensor for what does it tell you and what does it mean if the # is high because my friends own is reading 7 i think thats what he said
WeldingHank
Car: 1989 240sx CA18DET
it won't tell you if your having little knock. but if your getting really bad knock, it will spike to about 50-70, then be worried. i used to data log my dyno runs with it and where i would loose power, my knock had gone up on the safc.
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Its useless. It's mean to read from a generic raw knock signal from a sensor such as the J&S knock sensor.
1SlowCA18DET
whats an J&S knock sensor?
1SlowCA18DET
is there an alternative way the get a knock reading ?
