safc help
turbos12
Car: 1985 nissan 200sx
i installed an safc neo..and everything works except for throttle %..i tryed 2 different tps and still had the same problem..i ran a wire from the black plug on the to the tps wire on the ecu and it was only reaing 0% and 100% when i touched the gas pedal..it dont read anything inbetween 1 and 100% ..it goes straight to 100% no matter how much im pushing down the gas pedal..any help would be great
skunkmonkey
Car: 1993 S13 Coupe w/CA18DET
did you set up your throttle settings correctly? it should be under the etc. menu. with the ignition turned to on, not with the car turned on all the way. set your cyl to 4 and thr to the arrow pointing up. hit okay then it should go to the next screen wich sets your throttle signal voltage. setting the close setting... it's obvious... don't step on the gas pedal. and with the open setting... step on it all the way. hit okay and that should be it?
your safc should read the throttle percentage now... if everything is hooked up correctly.
