So I have a Safc on top of a Rom tune from enthalpy. I was having some rough idle and fueling issues (just put the motor together) and figured out my MAF wire was broken. Fixed that, now I have .5 signal output from the z32 maf. So that signal is going into the Safc. As far as I can tell all the values are zeroed out. However I was only getting .2v out of the safc to the ecu. I bypassed the safc and the rest of the idle issues went away. So my question, does the Safc only incorporate the tune when the engine is running? And how do you adjust idle Afr with the safc? Through the Dec air settings? I started with thr-1% and changed NE1 but saw no change in output voltage with the key on and the engine not running. Hope this makes sense and you guys can help.
Thanks.
