S14 KA24DE SE
BenjiD
Car: 89 S13 Coupe SR20 Mildly Built 2871R(GONE)
91 Hatch DD Wheels 5 Lug Brakes,Coilovers
S14 SE GTR Wheels Mostly Stock
Hi My car started with a rough idle this morning. After driving a short distance it started sputtering and losing power. Still idles rough. Checked the ECU and cam up with a code 56. Can't seem to find any info on this code. :confused:
angrypenguin182
Car: 91' Nissan 240sx
you're positive? this is the best i could find with a quick search
http://www.200sx.org/ecucodes.html
BenjiD
Used A Scanner and came up with 34 Knock Sensor.
ShouldaHadaV8
Car: 92 hatchback 240sx, j30 diff, TIEN tie-rods
The knock sensor isn't your problem it only retards timing by 5 degrees ,and its coming up as a result of the way your car is running. It will run without the knock sensor. Make sure your ECU didn't read 55 and get back with us. Im not familiar with s14 codes but I dont think 56 is one of them.
Check timing, MAF,TPS voltages first. check fuel PSI second. Then go from there. make sure you look up the FSM it has ALL the answers.
dlydrvn240
Car: 96 240sx
56 is not a valid code....if you checked it with a scanner you should have cleared the code..start it up and let it run, make sure problem is still present and then check again.
Codes and way to read from ecu are described here.... http://www.240sx.org/faq/articles/ecm_codes_doch.htm
silent_elite
Car: 1990 s13 with ka24de swap
check you tps and make sure its good, does your rpm on idle fluctuate hard then die down.
http://www.240sx.org/faq/articles/throt ... djustm.htm
BenjiD
I think I found the culprit. I neglected to mention I sprayed the engine down the day before. After pulling the plugs they looked water fouled. I replaces them, also put dielectric grease on the wires, and installed new z32 fuel filter. All is well for now. Thanks for the help guy's!!!!!!!!!!!!
