S-Chassis Eccentric Lockout Kit
-Get an alignment and be done with it. Remove those stock eccentric bolts that get out of alignment.
-Grade 10.9 Zinc Coated Metric Hardware
-Washers are Laser Cut to ensure quality
-Mild Steel Washers give the option of welding onto subframe, or paint them to prevent rust.
-Comes with 4 Grade 10.9 Zinc Coated Bolts, 4 Lock nuts, and 4 laser cut mild steel washers.
Price:$40 or $45 shipped
S13 to Z32 2+2 E-Brake Brackets
-Make your Z32 2+2 ebrake cables bolt on to a S13
-Stainless Steel and laser cut brackets allow for precision fit and strength. These don't bend unlike the other ones that have been on the market before or on ebay.
-Not for use with subframe risers unless you modify them
-Comes with all the hardware needed. 2 bolts with nuts and washers for cables to brackets and 2 bolt for brackets to chassis(Not pictured)
Price: $48 / $55 Shipped
This pic shows them hanging loosely. Just hand tightened without cables
Cables installed
