frapjap »
https://forums.nicoclub.com/frapjap-u17700.html
Mon Jan 26, 2015 12:31 pm
Welcome to NICO!
Bummer that your first post in our community is a problem with your SR.
If I had to venture a guess, you might have a Cam Angle Sensor or Crank Angle Sensor that is on its way out and won't send the correct signal to the ECU to start the engine. Alternatively, if you want to start cheaper, take a look at your starter and ground connections, or test your battery.
