S13 rear sway bar links installation torque
bcar240
Car: 1993 240SX HB
I just put some of the polyurethane Energy sway bar linkages on the rear and I am not sure what to torque them down to. The FSM recommends something really low, like 8.7 ft-lbs for the stock type, and I found a few various other forum posts recommending anywhere from that to 104 ft-lbs. That's a big range, so does anyone know what it should be?
Shadow Drifter
Car: 1990 240sx
TQ them down till they just start to crush make sure you use blue thread locker on the nut as well
bcar240
Car: 1993 240SX HB
Shadow Drifter wrote:TQ them down till they just start to crush make sure you use blue thread locker on the nut as well
Check, thanks! I set the wrench to 35 ft-lbs just as an indicator and I started tightening. I stopped when they started to show signs of obvious compression and there were a few threads sticking out the top of the nut, the wrench never clicked so it was somewhere less than that.
nofatchicks0073
Car: 91 hicas RIP
92 hatch RIP
89 hatch parts
90 hatch in the works
sounds like you did it right but 104 pounds oh my god where did you read that at i dont think i would be taking to much advice from that forum if i were you
bcar240
Car: 1993 240SX HB
Ya, it was some installation thread on FA. Funny that even though he said 78-104 ft-lbs on the end links, his didn't look much more compressed than mine. I am not sure that he got the right kit though, because I think every install I've seen required you to put a jack under the sway bar to get the threads to protrude on top and his stuck way through without any assistance.
