s13 - rb25 + 383 + boost = MATAfied's ride
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
540sx
Car: 240SX
like the passenger side header. do you have room for a sway bar with the crossover being down by the balancer. looks clean.
what size exhaust are you going to run off the turbo?
jegs and summit seam to make parts that are cheaper than the originals .
540sx
Car: 240SX
my bov only opens when i am at least close to 0 " vacuum at least that i can hear.
curious about bov opening when not under boost.i once saw a camaro with 2 gt45's rear mounted and the bov would open and close during the idle. seemed wrong but I am a noob.
matafied
Car: 1989 240 rb25det 1992 240 rb25det
450SX! wrote:like the passenger side header. do you have room for a sway bar with the crossover being down by the balancer.
yea i just put it on just to start it up, i am making some new one's, oh yea the sway bar is on, and it has plenty of room.
2 1/2 crossover pipe, to 3" Y to turbo and 3" downpipe
450SX! wrote:my bov only opens when i am at least close to 0 " vacuum at least that i can hear.
thats normal, some bov's are sinsitive and any vac at all can pull them open. I may not have a problem with that, i have very low vac on my motor.
540sx
Car: 240SX
nice size for the crossover , I used a 3 " , my turbo would probably spool a bit faster if I used the 2.5".
interesting about the bov. i had mine pulling vacuum from the little port on the carb throttle plate. 1/8 opening and there were two other things getting readings from it.
my new vacuum line set up has the blowoff opening when I rev it up in neutralnow. also a lot better repsonse when driving before I was getting compressorsurge and the flutter noise because it did not open enough.
Modified by 450SX! at 3:46 AM 7/12/2009
Speckid14
Car: 2002 SE-R Spec V, 1995 240sx, 1993 240sx Coupe
Curiousity is getting to me on how to make that gauge cluster. Looks incredible. Also doing a small block swap myself. Keep up the good work, everything looks new and clean. lol Write up for the street sign cluster?
matafied
wish i hed enough pics for a write up, when im working i forget to document my work lol
finally starting on my stupid manifolds, put my dad to work lol
240cp
Car: 95 240sx
Is it me or is there a very weird looking person standing behind the driver door on the top pic.
Sorry had to ask
jdmae86
Car: S14 - RB25DET SII
240cp wrote:Is it me or is there a very weird looking person standing behind the driver door on the top pic.
Sorry had to ask
lol
matafied
Sorry had to ask
i have been waiting on that
Meet BOB
240cp
Car: 95 240sx
Dude that wigged me out couldnt make heads or tails of it and to boot i just got through watching that movie The Unborn. With that little boy always in the back ground of pics. I know i'm a idiot.
540sx
Car: 240SX
what are you going to do for a hood scoop? also a design issue with building the cold pipe from intercooler to the throttle body is what kind of scoop are you using and will it fit under it. just a little heads up if you have not crossed that bridge yet. looks good , I'm jealous ,wanted the fuel injection too but could not squeeze into my budget.
matafied
450SX! wrote:what are you going to do for a hood scoop? also a design issue with building the cold pipe from intercooler to the throttle body is what kind of scoop are you using and will it fit under it. just a little heads up if you have not crossed that bridge yet. looks good ,
im just going to be running a 4" cowl, i measured everything up and it should fit ok.
450SX! wrote:I'm jealous ,wanted the fuel injection too but could not squeeze into my budget.
i thought that if i ran megasquirt it wouldnt be so pricey, i was wrong but it was not to bad
540sx
Car: 240SX
do you know if the contour of the hood matches the cowl( bumper to windshield curve of hood)? which brand you are going to use?
Mudvayne
Car: 91 240 sx 93 300zx 81 el camino 496stroker
450sx your hood looks sick bro u should market it yourself. how much would u want for one. matafied did u take the whole wireharness off. im worryed about my lights windows radio ect and i want to use the stock ignition was thinking of use the wires from stock starter will it work
540sx
Car: 240SX
thanks,
it is still in the works, might touch it up a bit before I make the mold of it.plan on laying it up in carbon fiber. some imperfections that might be noticed once it is all glossy.
I figure if the mold is good and my glass and carbon work turns out nice I will make them in either fiberglass or carbon per request.few months from now realistically.
I am trying to find a better source for carbon fiber to lower cost.it would depend on materials , glass or carbon.
in a few months if you still want one we can work something outreasonable .
Modified by 450SX! at 3:50 AM 7/12/2009
Mudvayne
yea hit me up when u make another one my email is in my name. want one for sure
matafied
Mudvayne wrote: matafied did u take the whole wireharness off. im worryed about my lights windows radio ect and i want to use the stock ignition was thinking of use the wires from stock starter will it work
yea it will work, i did not remove the whole harness only the engine harness. their are only a couple of wire's you need to tap into to make it work for you. eccs and fuel pump, the ka lower harness will work minus the transmissinon speed sensor etc.
s13junkie
Car: s13
did you keep the measurements for the oil pan? I plan to go in the same direction with a 383. What will yo do for headers?
rsagen
Car: 1989 240SX Coupe 5sp SOLD
1989 240SX Hatch auto SOLD
1990 240SX Coupe auto WRECKED
1990 240SX Hatch auto
1990 Jetta Turbodiesel 5sp FEILD BAGGED
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
^^^ BUMP! lol. Im looking for the measurements of the oil pan also, to use with the stock 1990 240sx cross member. the drawing you made was hard for me to read.
thanks
and ps REALLY NICE BUILD!
s13junkie wrote:did you keep the measurements for the oil pan? I plan to go in the same direction with a 383. What will yo do for headers?
Modified by rsagen at 2:33 PM 10/16/2009
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
matafield you traitor! i gotta go take a shower now i feel so dirty look at those v-8 pics!
matafied
yea sorry guys, has been awile since i checked the forums. do still have all of my measurements from the oil pan. i will try and dig them up for you.
i have been on 20hours a week overtime and have made slow progress but the manifolds are almost done
matafied
USMCgetsome wrote:matafield you traitor! i gotta go take a shower now i feel so dirty look at those v-8 pics!
man i still got mad love for my RB's
qwarnon
Car: 93 240sx coupe undergoing a 350chevy swap
you wanna make a front sump pan for me? and a pickup lol. let me know.. i have money
eaton89
Car: 91 240sx
ha, how is that pan holding up? Have you had any problems with the 2 seperate sumps? Have you ever pulled the pan to check things out? How many miles have you put on the motor with this combo? Sorry for all the questions but if the pan I'm going to try and use wont work then I was looking to do the same as your pan. It will be way cheeper than the alternative but then you already know this.
matafied
Update!! Whew well it’s been a long time over due
I have been so busy working on everyone's vehicles but my own; I have done 2 rb25 swaps, 350 in to a jeep Cherokee and have been helping a friend with his ls1 in to the FD. Yes it is sick lol
I’m am going to try and update regularly now to lol
My car has been at my dad’s house rotting away in his garage, until I finally broke down and was able to purchases a Tig.
[/URL]
So here is where I’m at with the manifolds, it’s my own custom design so be gentle lol and keep in mind I’m not done. I still have a tone left to do and alot of cleaning.
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
WDRacing
Nice dude Love the manifolds, they came out awesome
WD
jacksonbrown
Car: 1989 240sx/RB25DET , 1989 240sx/355 Chevy
Came across your build and looks like we have been bitten by the same bug. I have a built RB25 for my son and now I am working on my 355/TH350 build. I like the header work you've done, awesome. Heres a couple pics of my pan, pickup, etc. headers next on my list. The RB is a great engine with lots of power but I love the sound of a cammed up V8 with big stall converter behind it.
matafied
wow thats looking good. I should have some more pics up this week with the turbo mounted
jacksonbrown
what size, brand you going with? What kinda boost? Really need to post some good audio video of this thing running, cant wait to hear it with those pipes and Im assuming your just dumping exhaust in front corner.
matafied
nope lol running a 3'' downpipe down and out a single N1. I am going to dump the wastegate though.
Return to “Hybrids”
