91hatch240 »
https://forums.nicoclub.com/91hatch240-u173409.html
Sat Jan 29, 2011 2:24 pm
I have a 91 240 that I bought with an idle problem, assuming it would be an easy fix. The idle fluctuates between 1200 and 4000rpm and when I unplug the tps to adjust the idle, it stays right at 4000rpm. Adjusting the idle adjustment screw doesn't do anything. Previous owner converted from auto to stick, if that makes any difference.
here's a list of everything I have tried so far:
-disassembled and cleaned iacv
-replaced and adjusted tps sensor
-replaced almost every vacuum line, except for the ones for the pcv valve
-added an extra ground
-unplugged the maf sensor to see if that was the problem, idle still surged
-pinched the hose going from the iacv to the air regulator, to test air reg., no change
-ran ecu codes, came up with a 12- air flow meter circuit and 13- engine temperature sensor circuit
I'm out of ideas and can't seem to find anything else on any of the forums, so any advice would be greatly appreciated.
