Spiffy240 »
https://forums.nicoclub.com/spiffy240-u57557.html
Mon Dec 17, 2007 12:39 pm
ok, i have this same problem but i figured out a way
Listen:
On that part that houses the controls for the power windows there is a clip on the front of it (the part closer to the hinge on the door). When you pull on it, the clip holds it in and it is a PAIN IN THE ***! Get a small flathead screw driver and slowly pry your way around the piece. Be careful around the edges, its old plastic and it can be brittle.
Once u get some room to fit the flathead, locate the clip at the front and try pushing it in and lifting the piece up. Once you see it and it is up, things will go easier. Then start prying it up and watch out on the side closer to the door panel, that can be tricky too. Just maneuver it side to side and it should brake lose.
IF THAT DOESNT WORK:
Open the door and lay down on the ground underneath it. Pull the door panel on the bottom of it and pull until you hear and feel the clips let off the door. Now look up under the door panel in the gap and you will see the annoying mother fu**ing clip that annoys us all. Also, you can disconnect the unit wiring from it to make it a little easier.
I know i write a lot, but good luck. It can be a real pain, but once you figure it out, you'll know what to do from now on.
