s13 distributor wont fit in s14 head
Pro ViZion
Car: 1990 Nissan 240SX w/ KA24DE
Hi everyone I'm just wrapping up my engine rebuild. Finally got it all back together.
Anyway the block is a '93 and the head is a '95. I have everything all bolted up just down to the distributor now (s13). The problem I'm having is it seems as if my distributor is bottoming out or something. I know people have done plenty of these swaps and I have never read anything about this. It only reaches to about a mm before the o-ring on the distributor.
When I initially put it in the timing marks are lined up. Now if I turn it then take it out the marks no longer match. So I'm guessing the gear is making contact with the cam gear. Any idea on what is going on?
Btw I'm using a cometic headgasket if it makes any difference.
Thanks.
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
sometimes they are just tight, give it a little tap with a rubber mallet. don't go all buck nutty tho.
Pro ViZion
Yeah I figured out what's up with it.
The front timing cover is a tad taller than the head so its not lining up right.
I'm guessing its from getting the head milled down.
Pro ViZion
Well I ended up trying what you suggested and the distributor went in. But now I can't turn it.
Wtf is the deal. I noticed to that the upper timing cover is only slightly taller than the head on the distributor side. The other side sits flush. What gives. I even took it off to see if something was stuck underneath but didn't see anything wrong.
moso
90 240sx ka24de RIP
i got nothing, plane the head cover down until it lines up?!
costa_rican13
Car: 1993 s13 coupe
if you had the head decked/resurfaced, you need to get the top timing cover decked, to match. this is your issue with the tallness.
Pro ViZion
Alright i'l definately be taking it down there.
