nissanpunkrock »
https://forums.nicoclub.com/nissanpunkrock-u91046.html
Mon Apr 07, 2008 8:53 am
ima 5 speedwhat i did was took the exhaust cam gear off spun it till it was pointing perfectly out, then reinstalled gear and chainthen did same on intake side, took gear off, pointed perfect out, then reinstalled, then i had to reajust my exhaust one more time cuse after adjusting my intake it showed me my exhaust was still one tooth off.
really just make sure your at tdc, then just eyeball it to make sure both are pointing perfectly out, look at the pics of the #2 piston cam lodes on the intake and the #3 piston cam loads on exhaust, they also help to figure out where cams need to be pointed
to get the cams in, lay cam in, and if it dont fall in, take one journal at a time and slowly pull them down and it will pop cam in, but dont make anything bind or bend and dont stip the soft alluminum head, and take your time
search, find as many pics as you can and ALWAYS spin crank like 100000 times befor you start motor cuse valves and pistons dont like to touch
my 2cent
