Hi everyone!
As like many others ive been creeping this site for a long time for info, pics, inspiration, and ways to empty my wallet
ive finally got something cool in my car so i figured id start a build thread.
Got the 240 back in January of 2015
320,000kms on the clock
Dual cam KA
lowering springs and toiko adjustable struts
VLSD
Injen CAI
Picked up some XXR002 16 X 8 0et
Threw on my
Raceland coilovers
Isis GT Cat Back
Isis Short Shifter V2
Isis Tension rods and RUCA's
Dropped the subframe and re-did bushings w/ Energy Suspension S14's poly.
Found a R32 GT-R seat
Nardi Rep wheel and CS short hub/QR
This Is how she sits now
This is the CA18 i got for it
It was sold as-
T25 from an SR20
XSPower Tubular manifold
Braided lines for turbo
sr20 igtiter
NEW-
water pump/oil pump
timing belt kit
top end rebuild (not sure how in depth that went, but cyl head looks very new)
and mostly what comes with a motor set
basically looked liked someone just rebuilt this, as the cylinder walls had fresh honing/cross-hatcing
I ended up purchasing-
APEX'i ACV-R
Wiring specialties CA18 to S13 swap harness and coil pack harness (great guys to deal with)
XSpower CA18 FMIC kit-ended up getting a SR20 kit with 2 cold pipes, 1xS13, 1XS14, and no brackets for the core (issues with customer service)
Isis FPR + rail adpater
Autometer -Wideband, Water temp, Oil pressure, and Boost
Turbo elbow and 3" DP
samco rad hoses
This is how it started
I really wished that i took more pics of the actual mechanical parts of the swap, but was just too excited and i have a white phone sooo didnt wanna get it all grimey
In she Goes
We re and re'd the engines over a friday to sunday after work kinda deal.
things ceased on sunday when i tried fitting the FMIC piping,
as i said earlier couldnt get the cold piping lined up for the life of me (found out it was sr piping) .
hot side was not too bad, got it all to fit atleast.
over next week or so i got luck and found someone locally with ca18 stock IC piping and was able to make what i had work.
This is what i came out with-
At this time i am using a used EMUSA intercooler core and the brackets that came with it,
since i dont have brackets yet for my XSpower core.
Hahaha Now ti tried to start the car and crank crank crank crank crank crank crank crank.....
MF'er
tested for spark and had good spark
but found that no injectors were firing and no fuel on plugs...
The sad sick feeling after weeks of planning that you find out about the
DROPPING RESISTOR...
I should have read the instructions from Wiring Specs.
So 3 weeks later i get a Brand new dropping resistor from Japan thru my local nissan dealer
i plugged it in, hopped in the car and hit the ignition....crank crank crank crank crank crank ...AAAAAHHHHHH!!!!!!!!!
A couple of days go by and i realize that i can now feel and hear that the injectors are clicking after fixing some ground around the chassis area
so that promted me to remove the CAS just for poops and laughs
and look what i find!
Mother Freaking !@#%&!$#^@&#%^*#$^*&#^&%^#(&#%^& !!!!
Another sick feeling like being kick in the jewels when u see 1/2 moon missing out of the cam gear
Now, the weird thing is =
The CAS is good???? what???
So i throw everything back together and align the CAS and the cam best as possible to the 1/2 moon
And i fire it up for more Poops and laughs ... adn the Runs!!!1
for 3 secs at 450 rpm, but she runs!!
after playing with the timing and babying the throttle i got her warmed up and get her running well enough to build boost in neuteral
and have good A/F ratio's, oil pressure and water temps
But she still doenst want to idle
I have to Tee my cold start vavle off with intake manifold and intercooler cold pipe.
Following day i moved my car out of the shop and .... GREAT pool of fresh clear oil.
upon inspection my oil pump is leaking! WHY is a better question, its missing 3 oil pump bolts!
so either i was so ignorant that i didnt realize there was 4 oil pump bolts missing, or they rattled out while setting timing.
and i never found any bolts anywhere that would fit in the ca18 bolck
After hours of searching NICO ive fuond that the bolts is a M7 X 1.0 ? so i am on the search of those now
So that where im at with her now.
its been a hell of a journey and its not over yet
I Still need to get the front bumper on and signals wired back up
Decide on BOV location and recirc or not
Find a Exhst Cam-used or tomei Poncam if she hold up for that long
Try to find a power steering tensioner bracket for the Ca
Finish Tee=ing off my cold start/air regulator
Then when i get it all running and idling normally and get rid of this freaking oi lleak, I'll wire up the AVC-R
I plan to get around 220 to 240hp to the wheels with my set up.
My future goals-
Bigger injectors (GT-R maybe?)
Full Tune
Possibly Z32 maf if i can afford it before the tune
aluminum rad and e-fans if req.
Catch can set up
t28bb and external wastegate (or something bigger/better =D)
tomei poncams
Thanks for taking the time to look at my build !!
and thank you NiCO for ALL the INFO!!!
im trying to firgure out how to upload vids onto youtube properly so i can get them on here.
