s13.4
grengoboom
Car: 90-s13
hey im new here. but i have done some looking and cant find the answers i want, so question is on a 13.4 conversion are the finders wide i.e. 20mm or 30mm ? because every conversion kit i have found does not list this info. and i want to do 50mm in the rear, but it will be retarded to do this if it's stock width in the front...
also can you put this togeather with standard kouki s14 finders ? or do they need extensive modification to work... i would rather get flamed on here then waste money trying to make something work that wont... \
so any info would be sweet...
