ok first off i just put my safc2 in and i set it to 4 cyl, throttle up (0-5V), and hotwire 7 in and 7 out.so your fine there.but did you make sure to put the brown wire (ground)before the black (ground).its nothing in the safc that could cause it to not crank.so i know you have checked the wiring but do it again.from start to finish.when i put my hks turbo timer in i could have swear i done it rght but i missed one wire.and i checked it more then once. good luck with it .when you find out what was wrong let us know.mikesim wrote:ok, after blowing the head gasket, my friend and i got around to fixing the car and adding my turbo, afc and injectors.
the injectors are DSM 450cc, and fit in just fine after exchanging the o-rings from the stockers.
i added the DSMs to feed fuel for the GT2530 turbo.
i followed the wiring directions from the PDF on the website, and without much more info, i setup the car as 4 cyl, throttle up (0-5V), and hotwire 7 in and 7 out. i also took -5% at 800rpm on the low and high throttle maps.
now when the car is cranked, there's no indication of movement on the RPM signal on the AFC or on the cluster, and it doesn't start.
could it be flooding? or could there be something wrong with the sensor? or is the #of cylinders correct cuz its direct ignition? i've double checked the wiring already. the wiring is crimped together with a VS3 tool. (ideal for cutting, splicing and tieing two or more wires together in one simple crimp.)
Between 1-3k on the hi-thr settings, I would lean it out a good bit. The ECU has a natural tendency to pull timing hard at the onset of boost. I know when people do ECU retunes, they add timing in the that area. It gives a much better throttle response. Leaning out the SAFC will do the same thing since it will switch to a higher timing map with the less airflow. It's just pretty tough to get right with a SAFC since you are limited to just airflow correction and can't access the timing maps directly.mikesim wrote:-10 to 12 is pretty safe, but it tends to bog if i get on the throttle. should i do the same with the hi throttle afr's as well? just from 1-3K i'm thinking.
actually i was wondering if it was too low, lol.float_6969 wrote:What turbo is it? Regardless, if it's at least a T25, 9psi isn't too much.
